How to control the service button in the header?
EdpaEdpa Posts: 46
Sorry how I can control these buttons( now default in dialog) or remove them?
I do not need in  Help button  because I have a normal HELP with images in script and I want delete this button.
I don't know how to control  Exit  button .  I have to keep track of button click by user to return the 3D window in the the right state.
Post edited by Edpa on
  • Richard HaseltineRichard Haseltine Posts: 111,859
    Clicking X will be the same as hitting the Cancel button in the dialogue.
  • EdpaEdpa Posts: 46
    Hi, Richard!
    When I click my button Cancel -  my function begin to work too. When I pressed X, I exit from script only. :(
  • PraxisPraxis Posts: 292
    At present it seems there is no way to control or remove these buttons in Script.
    Edpa said:
    ... to return the 3D window in the the right state.
    You can execute your clean-up code AFTER the DzDialog.exec() returns ... This way it does not matter how the dialog terminates, your code will always be executed.  (You do not need or want a special Cancel button).
    For more on this, see: http://www.daz3d.com/forums/discussion/81136/partly-solved-how-to-detect-that-a-dzdialog-is-about-to-close
    -P
    Praxis, thanks.
  • YudinEdYudinEd Posts: 90
    edited March 2017
    Try this code for dialog without service buttons (only X button)
    var Dlg = new DzBasicDialog();Dlg.showCancelButton (false )Dlg.showAcceptButton (false)Dlg.showHelpButton (false) Dlg.exec()
    Post edited by YudinEd on
    There is a basic DzDialog that doesn't have any default widgets, rather thans tarting with a pre-defined dialogue (intended to make the UI more consistent and to give authers a simple starting point) and disabling features.
    edited March 2017
    ...deleted...
    Ok, I didn't know or did not pay attention when working with DzDialog  :)  Thanks.
