Can't change the light
LagrangeLagrange Posts: 111
Dont know what's heppening but my Daz worked fine for a year but last time non-top mistakes began. Everyday I solve one and immediatly a new one appears.
So. I keep some light presets in separate scene files to drop them into another scene. Some days ago a strange thing hapened - Daz remembers one exact light and renders only with it even if I deleted it from the scene and put there another one. I can delete all lights but I just can't use another. How fix that?
Post edited by Lagrange on
  • Richard HaseltineRichard Haseltine Posts: 111,306
    If you are using Iray is it set to use the Dome in Render Settings>Editor tab>Environment group?
  • LagrangeLagrange Posts: 111
    edited July 2016
    Sorry for not answearing so long. No, it was set to "Dome and scene".
    Changed to Dome - same result.
    Changed to Scene only - fully black character.
    Changed to Sun-Sky - dial controlable light, my own one doesn't influence it.
    Is the light set you are using made for 3Delight (or Poser) or is it an Iray light set?
    Damn... Yes, they are 3delight. I thought they give some result anyway like shaders do. They don't?
    No, not reliably - in geenral the Intensity slider, which is the 3Delight control for brightness, doesn't work well in Iray.
    Thank you.
