Updates for products installed using Connect available only through DIM
DIM displays that there are updates available for a few installed products which have been installed through Connect. But when I login to connect and browse those products in Products section of the Content Library, there are no updates visible even though I try to manually update their metadata. Even the product documentation page does not list any updates for the products.
For example, right now I am seeing updates for FWSA Quinn, Livia, Iray memory assistant among others in DIM but Connect doesn't show any updates for these.
What kind of updates are these? Do we need to check for updates in DIM even though the products were installed through Connect?
  • Richard HaseltineRichard Haseltine Posts: 111,332
    DIM update notices are based on the DIM version and take no account of anything downloaded with Connect (you can tell DIM not to show Connect-installed products in Ready to Download). So your files in Connect may be up-to-date while the files in DIM aren't. DS will use the Connect version, if present, in preference to a DIM install.
  • Sensual ArtSensual Art Posts: 646
    Thanks Richard. I unchecked the "connect available" and "connect installed" options in DIM filters and those updates disappeared, except for Anderson Hall Vestibule Ps. Anderson Hall Vestibule was also installed through connect and does not show any updates in the studio. Seems like Poser related files are still showing up for some items even if I have the Poser filter options unselected in DIM.
