homestyle iray shaders updates?
I installed an update to the homestyle iray shaders parts 1 & 2 but keep getting updates back in the dim. I think I've installed updates at least three times but keep getting updates back in the dim.
I've tried uninstalling and reinstalling but it still  happens. Its a quite iritating!
  • I've had problems installing stuff before, I think that the dim can conflict with connect. Im not sure wether this accounts for this problem as it seems to affect the dim installs!
  • Richard HaseltineRichard Haseltine Posts: 111,363
    If you hover over the item is the tooltip listing the current package date more recent than the last download? There were several updates to the shader packages in quick succession.
  • I looked in the folder where the files get downloaded to and found that there were two versions of each file, one set had a 2015 date and the others had a 2016 date. Not sure how there could be two files with the same name in the same folder! Ive deleted the older version and hopefully this has solved this issue!
