Transfer Morphs from Genesis 3 to Genesis 2
faisanfaisan Posts: 602
It's incredible, but I'm asking for if there is a way to trasfer Morphs from Genesis 3 to Genesis 2. Yes, I didn't get wrong. I want to transfer from Genesis 3 to Genesis 2. The reason is I work in Poser, and Genesis 3 has a lot of issues working in Poser, because it isn't compatible with Poser. I didn't have problems working with Genesis 1 and 2 in Poser, but Genesis 3 is impossible to work (it isn't exported correctly, the viseme map doesn't work, animations don't work, etc.) So I decided to work in Genesis 1 and 2, especially 2 for Genesis 3 morphs, but I'd like to know if there is a way to transfer them. I know there are methods to transfer morphs from Genesis 2 to Genesis 3, but I want from Genesis 3 to Genesis 2.
So, can you help me guys?
  • Richard HaseltineRichard Haseltine Posts: 111,598
    Do you have the Genesis 3 ... for Genesis 2 ...  clone for the figure you want to use? If so the same techniques should work - however, most Genesis 3 expressions are not morphs but bone transformations so they won't be transferable.
  • KeryaKerya Posts: 10,943
    I think you need
    http://www.daz3d.com/genesis-generation-x2
    AND
    http://www.daz3d.com/genx2-addon-for-genesis-3
    This add-on extends Genesis Generation X2 (GenX2) to the world of Genesis 3. Now, it's possible to transfer morphs from Genesis, Genesis 2, and supported Poser figures to Genesis 3 Male and Female. In addition, morphs may be transferred from Genesis 3 to Genesis and Genesis 2 or between the Male and Female version of Genesis 3. Facial expression joints of Genesis 3 are adjusted to the transferred morph if required.
  • faisanfaisan Posts: 602
    Kerya said:
    I think you need
    AND
    I think this can help me. Thanks!
    No, I don't have it. But probably I'll have to purchase them, because I need G3 Morphs in my G2 Figures.
    At Rendo, there's a free utility to use G3 in Poser with expressions, but apparently it doesn't work with Macs or you need to get some other app to get it to work on a Mac...
    edited July 2016
    Yes, I knew about it, however although I got to transfer Genesis 3 in Poser, it has a lot of issues: animations don't work (even in Daz Studio), viseme map doesn't work, etc. The problem is Daz didn't create a DSON Import for Genesis 3 Figures, therefore it isn't compatible with Poser and that's why I had these issues. Genesis 1 and 2 worked perfectly because Daz created their DSON Importer, that's why I want to transfer the G3 Morphs into my G1 and 2 Figures and work with them in Poser without problems.
    Post edited by faisan on
    The other way round - the Genesis 3 figures are not compatible with Poser and therefore Daz didn't create Poser Companion Files (for the Daz Studio DSON files).
    Exactly. That's the problem.
