Anyone use Torso UVs for G3F Anatomical Elements?
I've downloaded from Rendorosity but fail to apply it as instructed. Here is what I've done so far. If I miss anything, please let me know. Thank you!
Instructions for use
1. Load the Genitalia onto Genesis 3 Female.
2. Apply the same Shader as the Torso Surface for G3F onto the
   Genitalia. Usually this will be the AoA_Subsurface Shader which
   can be found in the DAZ folders at Shaders > Age of Armour >
   Subsurface.
3. Copy the Torso surface for G3F by right-clicking it in the
   Surfaces tab and then paste it onto the Genitalia surface.
4. Change the UV Set for the Genitalia to "Base Female Torso UVs".
  • nicsttnicstt Posts: 11,715
    What's your issue?
    Just downloaded as I'm curious about your reason for posting; the simple answer to your question would have been no, however it is now yes.
  • Cayman StudiosCayman Studios Posts: 1,145
    iSeeThis, I have received your Sitemail at Rendo and will reply to you there.
  • iSeeThisiSeeThis Posts: 560
    Sorry, nicstt, the pix doesn't show as expected. I showed what I've done.
    Cayman, you are so kind. I'm so glad you hear my voice!
  • gMAKgMAK Posts: 26
    I have the same issue as iSeeThis - however im supernew to Daz Studio - and for sure am missing something, but no idea what.
    See if you can contact the PA on rendo.
    In the mean-time, I can try and help; I tried them out after the post and have them working. Might be worth doing via PMs considering the subject, and the possible requirement for images.
  • Roman_K2Roman_K2 Posts: 1,277
    ceba said:
    I have the same issue... im supernew to Daz Studio - and for sure am missing something, but no idea what.
    I have noticed (at least a couple of times) that the files for digital models can change. See my current (summer 2016) post about the Blenworth castle for example -- http://www.daz3d.com/forums/discussion/101571/ -- where it's taken me several tries to get it right, and I reference a thread that seems to mention a list of updated DAZ products, and "Blenworth" is mentioned in the list.
    Hope this helps - maybe not with your specific issue, but just overall: understanding the various products and the distribution and updating process.
