I Bought Sickleyield Clothing Smoothers for G2F
I just found out that I bought this.  I have no idea when and I think the reason I forgot is because I can't see it anywhere. Not in DS in the runtime, no dials in my G2F character. I did find it on my hard-drive in a folder called Support (in the Runtime). I redownloaded the install files, but there's no documention and just the sames files in the same locations where I already found them installed. Can anybody explain what I need to do to get this working?
  • KindredArtsKindredArts Posts: 1,354
    I don't own the product, but i did do a little digging. i found a post on deviantart by sy saying it's a dialed projection morph, which apprently means the morph is dialed from the characer and projects on to the clothing. Click on the character and search for the morphs listed on the product page (i.e Victoria 6 Smoother 01) and see if it pops up. If so, dial it in and see if the clothes are affected.
    Yes there are no use facing files for this.  If I remember correctly its the parameters tabs when you have the clothing on the model.
  • KnittingmommyKnittingmommy Posts: 8,191
    Is that where I got those?  Those are really handy, but I couldn't figure out which product I got those from!
    lol yes
  • shadowhawk1shadowhawk1 Posts: 2,211
    If I remember right you will have a folder in your clothing folder that says !fit or just fit. Inside that you will find what you need to make it work. All you have to do is click on G2f and then apply and after it is done you will get a popup box that says it is done. Once you do that you will have a bunch of new sliders in the parameters tab for your clothing.
  • sandmanmaxsandmanmax Posts: 992
    Thanks, everybody.  I found it.
