Help on render output
Hello,
I have installed DAZ on another PC in the house and getting odd render results, even though the settings appear to be the same.
(I blocked out images incase I broke any forum rules) See pic 001, this is the image from the original PC (which is the texture I want). Its Victoria 7 with all default iRay settings. I do the same thing on the new PC, and I get whats in image 002, a washed out looking skin texture. I cant for the life of me figure it out. Any suggestions would be much appreciated. Thanks - J
  • Richard HaseltineRichard Haseltine Posts: 112,067
    edited July 2016
    Please see http://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest on ways to present images with nudity - in this case it would have been best to clothe them since you did need to show a render.
    It looks as if the first image is rendered with scene lights while the second is using the default HDRI environment light - check Render Settings under the Environment group. A saved scene should include render settings, but a subset (or a scene Merged into the viewport) won't.
  • Thank you Richard, you were correct. That has helped a lot!
