dzcontentdbeditor.dll issues.
fastbike1fastbike1 Posts: 4,082
I'm geting the following issue, which occasionally seems to hang Studio during intial load. Curiously, if I use Task Manager to cancel the process (which takes several tries) Studio loads right away immediately after.
Using Studio version 4.9.70 on Windows 7 64 bit.
Where would I look for a "new" copy of the dll?
Plugin failed to load!
Filename :
D:/Apps/DAZ 3D/DAZ 3D/DAZStudio4/plugins/dzcontentdbeditor.dll
Name :
dzcontentdbeditor
Author :
Unknown
Version :
0.0.0.0
Reason :
Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio."
Post edited by fastbike1 on
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Uninstall DS.
    Make sure the .dll file is really gone (I suspect it's from an older version of DS and simply shouldn't be theer, so you may need to remove it manually)
    Reinstall DS.
    Thank you Richard, that seemed to work. You were correct. When I uninstalled Studio 4.9.2.70, the dll was still in the plugins folder.
  • Thank you, it helped me too. yes
