Coupon of expired PC Membership not valid.
morkmork Posts: 278
Hi.
I had one coupon left (6% off DO) when my pc membership expired in april. It is still showing up in my account to this day, although the code has changed each month.
I thought, nice move, I can still use that remaining code at some time. But today, when I finally found something I could use it on, it does not work - "Coupon code XY not valid" :(
I have in my cart:
Aiko 7
Razo-Cut Bob Hair
Alliance Outfit
All three are non-pc items, daz originals, for which the coupon "6$ off originals" should apply for:
"$6 off Daz Originals. Excludes Platinum Club items, gift cards, and memberships."
So, is either my assumption wrong that I can still use the code - then it should be removed from the member area (I'd also recommend to check what would happen in my case coupon-wise, if I'd resubscribe) - or is there something not working with using an coupon of an expired membership, or am I missing something completely different? :)
  • Richard HaseltineRichard Haseltine Posts: 111,348
    No, you cannot use the coupon if you are no longer a PC member. I'm nor suer why you would see the coupon codes at all, I will ask.
