Question about managing keyframes
jdavison67jdavison67 Posts: 690
edited July 2016 in The Commons
I had a problem while draping a dynamic item with keys in my animation.
To get the best drape I went with the animation option, and started with one key at the first frame of my character in the "T" pose.
The last frame, at frame 45, was my character in the pose I wanted to use.
After resolving issues with my dynamic controls, I was able to get the drape I wanted, and I froze it.
Now I wanted to save this character as a subset without all the keyframes.
From past experience using keyframes in other software, if you only have two keyframes and you delete the other, the remaining keyframe should define the pose.
This did not seem to be the case. My attempt to delete the first key did not result in the other key pose being the shape result.
Also, I thought  I could move the keyframe from frame 45 to frame 0, and that would work, but I was not able to reposition the key.
Is there a better way to get what I want here?
JD
Post edited by jdavison67 on
  • wolf359wolf359 Posts: 3,951
    Hi in, Daz studio, you should not have to delete the first keyframe.
    Go to the last frame (your desired pose frame ) and select Save>pose preset.
    You should be presented with the option to save CURRENT frame or
    animated range.
    Tick the "current frame" option and save and that should save only the last frame as a single pose.
  • jdavison67jdavison67 Posts: 690
    Thanks so much!
