Animation for beginners
nubianbdsmart
in The Commons
I was just wondering does anyone have any advice for purchasing an animation tool for a beginner. I prefer to purchase something through the Daz Market Place and something simple and easy to learn.
If you have Carrara there is an awesome tutoral by MMoir on how to create a walk cycle. Even if you are not using Carrara it identifies how a walk cycle works and how to make it look good.
http://www.daz3d.com/create-a-walk-cycle-in-carrara
Hi,
I don't want to hijack the thread but, I was wondering what the difference is between the basic version of Animate that's included in Daz3D and the full version of Animate 2 that can be purchased from the Daz site.
Thanks
Yep, I have that. I haven't done much in my copy of Carrara as I mostly use DS, but this really helped me figure out how to fine tune a couple of "walk cycles" I was working on for a kata animation with movement of the blocks and punches combined with the movement of the karate stances during the kata inside DS.
Thanks for all the advice, although a lot of it I dont understand. How easy was it to learn if you have no ideo how to create animations? Also I didnt know there was a basic version of Animate already included. I use version 4.9 of Daz.
http://www.daz3d.com/forums/discussion/8081/what-s-the-difference-berween-animate2-full-version-and-lite-version
Here, this thread has you covered
Animate lite is included with Dazs studio so there is a good place to start.
As for how easy it is to start... I started Daz in March 2015 (properly, I actually signed up a few years before then!) I'd always wanted to do some animation but actually only recently (end of may) started it. Before I got used to lighting, camera etc and generally using Daz for still images and assets. There are a lot of tutorials which give some good tips on animating and in Daz whether you use animate or just the dazzling time line for it you'll want to learn key framing.
An easy start to look at this could be to set up let's say 60 frames (default is 30 frames a second so 2 seconds of animation)
Load a character in and pick a pose or pose them to your liking in frame 0 and add that as a key frame. Scrub the play head through to frame 60 and pick a different pose and add that as a key frame. When you press play studio will fill in the frames between the poses getting you from one to the other, it's at that point you'd need to tweak frames along the way to make the transition look as natural as possible.
I would start with some of the great animation tutorials that were uploaded to the DAZ 3D YouTube Channel. Here are a few to get you started.
There are lots more, but these will give a start to understanding how things work.
Thank you ^^
On the back of Knittingmommys post, I was going to create a quick tutorial demonstrating the normal timeline pose to pose animation I outlined above, turns out Daz have already done a decent one covering EXACTLY this and is a great starting point to just get a basic feel of what's going on under the hood:
https://youtu.be/r05ZysHDkPU
Thanks a lot, all of this has really been helping!
