Daz 4.5 problem with 'inflated' figures (nudity in attachment)
sberlinssberlins Posts: 128
edited October 2012 in The Commons
I know this popped up earlier as a problem and I recall that there was a file to run to solve it. The default genesis figure is inflated when it loads. Once this was solved all was well. Now every genesis figure I try to load is an inflated female body. See attached picture. This is also adversely affecting .duf files I had already saved. It just started doing this (without any additions or modifications to the program).
Any help?
Image removed for nudity. Please see this thread for info: http://www.daz3d.com/forums/discussion/3279_98/
Post edited by fixmypcmike on
  • TotteTotte Posts: 15,110
    Have you installed the "better V5 free morph" from ShareGC?
  • sberlinssberlins Posts: 128
    I do recall installing a 'quick fix' from Daz, but for whatever reason, Studio simply stopped working properly. No, to the best of my knowledge I have not installed a 'better v5 morph' from ShareCG. Going to share CG returns over 10 pages of items when I do a search so don't have time tonight to try and run that down. I was just hoping that someone here at Daz could point me to the proper file on this site.
    Inflated figure in bikini to illustrate the problem. Also, just upgraded to newer version of Studio Pro and no help.
    361 x 536 - 76K
    I found the item that caused this problem for others: GENESIS-V5.1 from ShareCG
    If you install that, you will experience the problem you have, and it is not something DAZ can fix as the problem is caused by broken morphs.
