Input please for my first clothing?
SkpFXSkpFX Posts: 42
edited June 2016 in New Users
This isn't about the models so much, as the "wearables" setup, and the zip file. The file contains two items, a pair of shoes, and a very rudimentary begining of a corset (that's actually three items, I guess). They seem to work as intended on my system, and I think I've gathered up all the pieces into the zip file, but I'd like some input as to what I might be doing wrong.
Also, this is the sum total of my knowledge so far... so any input about where I need to go next would be appreciated.
Keep the models if you wish (CC0)
EDIT: The file is for G3F.
EDIT2: File removed. It was broken.
Post edited by SkpFX on
  • Cris PalominoCris Palomino Posts: 13,060
    I would recommend putting up some images for people to see.  People may not want to download an unknown zip.
  • SkpFXSkpFX Posts: 42
    Nah, it ain't no thing. It's not about the models, they suck. I wanted to know if the file was sound... it wasn't. I rebooted into my old system and installed it. The objs were missing. It works now, and I understand DS better.
    Poking around it looks like the old mesh data went into .../Runtime/Geometries
    Is the new standard .../data/VendorName? I'm assuming that .dsf is mesh data?
    edited June 2016
    <double post>
    edited June 2016
    OK, this is what it is/was...
    I took the other thing out, now the file is just the two shoes.
    Files contents...
    Content/data/SkpFX/SaddleShoes/Skp_SaddleShoes.obj
    Content/data/SkpFX/SaddleShoes/Skp_SaddleShoes.mtl
    Content/Runtime/Textures/SkpFX/SadddleShoes/Skp_SaddleShoes-D.jpg
    Content/Runtime/Textures/SkpFX/SadddleShoes/Skp_SaddleShoes_UVs.png
    Content/People/Genesis 3 Female/Clothing/SkpFX/Saddle Shoes.duf
    Content/People/Genesis 3 Female/Clothing/SkpFX/Saddle Shoes.duf.png
    And the installed file shows up in the Content Library as...
    The model is really in need of decent materials, especially the socks. The Texture file is just solid colors, but I've included a UV image should anyone want to texture them.
    EDIT: It was broken! Updated file to include auto_adapted geometry.
    400 x 550 - 46K
    zip
    zip
    Skp_SaddleShoes.zip
    1M
    I truly don't understand what's going on. The first time I took this to a another mahine it complained about a missing .obj file, and worked fine when the .obj file was added. Now I see that there's an auto adapted .dsf file that also needs to be included?
    It's a whole lot of trouble for a pair of shoes, that aren't really good shoes. :)
  • LeanaLeana Posts: 13,663
    edited June 2016
    Actually what you should do IMO, instead of providing obj + auto adapted files, would be to save your item as a prop/figure asset (save as > support asset > prop/figure asset)
    It will then generate a duf for that item and a proper DS-format geometry instead of a "I just converted an obj to DS format" geometry file in data/<your vendor name>/<your product name>/ as <your item name>.dsf
    So assuming your vendor name is SkpFX and your proruct name is SadddleShoes with asset saved as Saddle Shoes 1 your zip would include:
    data/SkpFX/SadddleShoes/Saddle Shoes 1.dsf
    People/Genesis 3 Female/Clothing/SkpFX/Saddle Shoes 1.duf
    People/Genesis 3 Female/Clothing/SkpFX/Saddle Shoes 1.duf.png
    Post edited by Leana on
    Thank you Leana!!!
    I think I see what you're saying. Will try to work it out. :)
