Sub-D settings hidden after applying
Has anyone seen this recently (DS4.9.2.70) Apply Sub-D save as a Figure/Prop assest and open DS, load prop and this is what I see. If I show hidden the sliders show but this is not how it should work given my years of using DS and Sub-D. Is this a bug that needs reporting?
432 x 299 - 69K
  • Jim_1831252Jim_1831252 Posts: 728
    It does look like a bug. I haven't tested it out though. Does the mesh load as subdivided?
  • SzarkSzark Posts: 10,634
    Yes it loads with the High Resolution setting just no parameters like in the image
    edited June 2016
    Just gave it a go. I had no problem. I could control the subdivision level as normal.
    Have you tried saving a different version or a different mesh to test if it happens again?
    Post edited by Jim_1831252 on
    Strange behaviour indeed as I tested it myself with a cube and had no problems and then tested it on a prop and the same thing happened. Thanks for testing for me though I appreciate it.
    Weird. I just tried again with a different prop. Still works as usual. Which version are you running? I'm running the latest stable.
    yeah lastest stable 4.9.2.7
    Did you end up submitting that ticket?
    No not yet I need to get it all straight in my head first, plus I have more testing to do.
  • Richard HaseltineRichard Haseltine Posts: 111,852
    4.9.2.70
    is that a question or a correction
    The numbers are integers separated by dots, so the trailing zero matters - seventy not seven.
    Cheers I will remember that. :)
