view controllers obscured when tabs on both sides open
In daz studio 4.9 running on a mac.
I have had this issue for some time perhaps since d|s 4.5. my viewport seems to function fine if I have no tabs open or one tab open on either side. However, when I have a tab open on either side of the viewport then the right tab seems to crowd out the view controllers in the upper right corner. In order to use them I must continually close one tab or another and it is highly frustrating. When I do close one of the tabs the controller comes back into view right away. I actually used to get this on my pc but somewhere along the way it stopped happening. Unfortunately (in this regard) my mac is my big design machine.
anybody ever have this issue?
  • Richard HaseltineRichard Haseltine Posts: 111,831
    Close the Shader Mixer and Shader Builder panes, docked with the viewport.
  • ChakradudeChakradude Posts: 301
    Wow, I need to check my posts; that worked! I actually did not have the tabs you mentioned opened but I did have some other tabs (don't recall which) that seemed to have a non-flexible width or at least a large minimum width. Closing them solved the problem.
    Thanks Richard!
