any luck with g2 6 HD Add-Ons?
i bought this for some reason   http://www.daz3d.com/gianni-6-hd-add-on
can't figure out which way to go to try and get it to work?
is it subdivision, or displacement?
sounds like a project and a half, eh
any ideas or suggestions?
thanks! cheers!
oh my, working up a thirst
  • barbultbarbult Posts: 27,202
    You need to dial in the Gianni 6 HD morph and set Gianni 6 Mesh Resolution (in Parameters pane) to Render SubDivision 2 or higher. I think 3 is recommended. Leave the viewport Subdivision at 1.
    thanks.  parameters pane in carrara?
    ise goin blind  >.<
    Oh, sorry. I didn't see that this was in the Carrara forum. I can't help with that.
  • BrianP21361BrianP21361 Posts: 816
    HD isn't supported in Carrara.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,186
    edited June 2016
    there is a painfull iffy way you can do it'
    • pose your HD figure in DS with the mouth open using the bones, tongue posed  inbetween
    • up the subdivision as suggested and export a tPosed obj
    • import the obj and on the original figure select the rigging tool and rightclick bake rotations
    • use transfer utility pick your figure in the morphs dropdown for the source use near vertices as near as you can get far left, select morphs and on right add all and replace source with figure
    • run it and pray it does not crash
    • repose mouth shut and bake rotations again
    • save as support asset under new name again pray it does not crash
    • this is best done in DS4.8 or earlier btw too
    do not expect any clothes to fit, you could add a posed geograft to the obj though at that step with a few morph positions and use the weight brush after rigging to add it to pelvis and render him nude
    would want to put some celtic jewelry on him, no clothes to cover up the hd details smiley
    well, 4 cores not enough rendering power.
    deko cores!
