Saved Genesis Morphs Keeps Resetting
BurstAngel
This is getting very annoying. I'm hoping that it is a human error. I have saved a morph for genesis that I like to use again, but everytime I reload it, the shape is resetted. Why is that? I have to go back by hand a redo the slider EVERTIME. I've saved it as a scene and a character.
I'm using Studio 4.5.
Please Help!
How are you saving the morph and the scene, what format?
If you morph Genesis, and then save it as a Scene, it should not load an unmorphed Genesis.
What version of DS4.5 are you using? Help > About DAZ Studio?
EDIT:
I just tried this. I morphed Genesis, and saved as a DUF Scene Subset, saved Genesis only, and it worked fine.
I then saved as a Character Preset and that worked too.
Do you have Genesis loading when you startup DAZ Studio? Is that maybe the figure you are seeing?
I'm using DAZ 4.5.
I like to start with a clean scene, then load genesis. It is a .duf format since its then only one available. When I load my saved genesis figure, the texture loads just fine but none of the morphs are dialed. I don't use the subset save, just the scene and character saves.
I don't know why you are loading Genesis before loading your scene, since it already contains Genesis?
Just load your saved Scene into a blank new scene.
When you load a new Genesis figure, you are asked if you want it to replace the already loaded figure or not, do you not get that option?
I do. No matter what scene I save, the genesis morphs resets itself. The textures load, in the parameters tab, it show which morphs I'ved locked. But almost every morph goes back to its default position.
Okay, I tested out a little theory, it seems all the Genx morphs are the ones that are being reset.
Yeah!
I fixed it!!!
Apparently I miss some updates to both GenX and DAZ Studio 4.5.
