Genesis Generation X X2 add-on not working...
When I open the plugin it is constantly giving me the GenX menu even though I upgradinedf to GenX2. I have reinstalled three times. It is as if GenX2 isn't even there. Does anyone know how to fix this issue?
-DrDrk
Are you sure you installed only the GenX2 files?
I installed both in order of creation... Was I not supposed to do that?
-DrDrk
I don't have the plug-ins so I'm not sure, but apparently the only UI difference between the two is an option at the bottom of the pane/dialogue. You may want to look in the main support thread http://www.daz3d.com/forums/discussion/94881/genx2-update-genesis-3-add-on#latest
You have to remove the older GenX version (d3dGenX.dll in the plugin folder) or GenX2 will not load. http://www.daz3d.com/forums/discussion/94881/genx2-update-genesis-3-add-on/p3
