Having a problem with Genx2 and Studio 4.8
I'm having trouble with Genx2. I haven't used in a long time, but tried yesterday.
The Genx ui isn't showing the GenX2 screen, just the older GenX one; no Target selection is offered.
I've tried reinstalling both GenX2 & 4.8, Plugins says both are loaded. I assumed it was a Serial Number issue, but there's no option presented to enter Serial numbers.
Any suggestions?
  • LindseyLindsey Posts: 2,017
    edited June 2016
    The GenX2 ui tab title still says GenX.  The only noticible change with GenX2 is "Source" button under the "Load Figure" button to load Genesis figures as sources.  If you installed the recent GenX2 update, there is a new "Connect Path" button towards the bottom right where your DAZ Connect Library path is defined that allows the GenX2 to find additional Genesis morphs (and Genesis figures if they were installed with DAZ Connect).
    Since you're missing genesis figures in the Target button, click on the "Connect Path" button and check that the path to your DAZ Connect library is the same as the path defined within Daz Studio in Edit>Preferences>Content Library.  Mine was pointed to Daz Connect library in my Public folder which I don't use.  If you need to update the path, make the change and Exit Daz Studio and relaunch to refresh the GenX2 source genesis figure and morph scanning.
    726 x 880 - 115K
    Post edited by Lindsey on
  • And make sure that you have no older GenX active (GenX.dll in the plugin folder), if present, GenX will be loaded and not GenX2... The old version is obsolete and can be removed.
