Powerage's Live Architectural Bundle use
How do I use this product. I can't find any help file.
Thanks
  • SigurdSigurd Posts: 1,095
    Second this.
  • Charlie JudgeCharlie Judge Posts: 13,629
    edited June 2016
    I'm not sure which particular item you are trying to use. But you may have to look a little for the shaping morphs. As an example I loaded bthouse. With the main object selected it doesn't show up but go to the scene tab and select "base' directly under bthouse. Now open the posing/shaping pane and select shaping. You should see the breaking morphs available for use by adjusting the sliders. Attached is a quick render exploding the house.
    1525 x 849 - 250K
    Post edited by Charlie Judge on
