4.9 crashes Zbrush when I try to send
I just installed 4.9 pro on a new computer, and I have Zbrush 4.7 with GoZ. I've used this setup with previous versions on previous computers for several years with no problems. Now I'm crashing Zbrush every time I try to send something over from DAZ. Has anybody else had this problem? I just installed the latest version of GoZ from Pixologic, and my DAZ version is brand-spankin' new, but that didn't fix the problem.
  • Richard HaseltineRichard Haseltine Posts: 110,795
    It may be a corrupt project file from the first attempt - go to C:\Users\Public\Pixologic\GoZProjects and remove the project files (I can't recall if there are any other files in there, and can't check just now) then try again.
  • MythmakerMythmaker Posts: 606
    edited June 2016
    4R7. I have recently installed DS Pro 4.9.2.7.  No big issue from the get go, only one case of minor hiccup, solved.
    I didn't installe "latest" GoZ from Pixologic recently, was the same GoZ I had since 4R7 patch3 months ago.
    On checking DIM, my GoZ was automatically updated together with DS 4.9.
    My experience from past odd GoZ behavior after DS update:
    - with only DS opened (ZBrush not opened), GoZ a Genesis. In ZBrush make some vertices change, GoZ back to DS. ZBrush should now detect updated DS.
    In most cases, this should re-establish lost relationship. If that doesn't work
    - Go to Tool and press the R buttton to "Reset the selected GoZ enabled application" (Next to GoZ - All - Visible - R)
    if still doesn't work
    - Go to ZBrush Preferences > GoZ > Clear cache files. Then press on the Path to Daz Studio button. Select one of the DS versions (if you have multiple DS installed).
    Good luck!
    Post edited by Mythmaker on
  • Thanks for the suggestions. I cleared the Zbrush cache and found that 4.7 has buttons to establish paths to everything except DAZ in my installation. I will contact Pixologic; it's their program that's crashing and can't find DAZ 4.9.
