RIB 3DELIGHT equivalent for IRAY rendering?
Hello
I saw there is possibility to make renders ==> RIB with 3DELIGHT
is there a such possiblitiy for IRAY ? or Using  http://www.nvidia.fr/object/iray-server-fr.html ? Goal is
to make 1 (or several renders) dispatched on several machine ? Possible ?
  • mikael-aronssonmikael-aronsson Posts: 607
    edited June 2016
    No RIB files in IRAY, and I would not count on getting it either, not an easy task to implement, and sending asset files to multiple machines would break the EULA I think.
    Post edited by mikael-aronsson on
  • areg5areg5 Posts: 617
    I don't know about Rib, but I've been using the Batch Renderer for a few weeks and I think it will do Iray.  Haven't tested it yet, but there are quality options and one of the options is to use the scene settings.  So I think if the scene settings are Iray it may well render in Iray.  I'll check it later on today.
  • MedzinMedzin Posts: 337
    Are you talking about this product Batch Render for DAZ Studio 4 and RIB (http://www.daz3d.com/batch-render-for-daz-studio-4-and-rib)?
    It was released almost three years ago (quite a bit before Iray was on the boards) and specifically states in the readme that it is for the standalone 3Delight renderer.
    Actually, the statement "or any other render engine that can batch render .RIB files." is not quite true either. RIB stands for RenderMan Interface Bytestream.  Pixars Renderman does not understand RIB from DS because of differences in shader descriptors.  The same goes for Maya.
  • Cris PalominoCris Palomino Posts: 13,038
    File > Export... : Mental Images Scene Format (*.mi)
    Yes.  But it really isn't.  I tried it out yesterday, and rendered 3 Iray images.  You have the option to load 3Delight render quality options, in which case it uses 3Delight.  But you also have the option to use whatever render options you saved for a given scene.  I had 3 Iray scenes I loaded into it, and it rendered Iray.  Guess they were ahead of their time when they made it.  I love thie thing.  As long as there are no holdups like the dreaded "duplicate files found" message that pops up quite often, it just goes from one scene to the next.  I can set it to render 20 scenes overnight, and they're done in the morning.  Won't do animations though.
  • ToborTobor Posts: 2,300
    I wonder what version of Iray they use in the Standalone version.
  • FirePro9FirePro9 Posts: 456
    Not sure this is the same product, but claims to work with iRay:
    https://www.renderosity.com/mod/bcs/batch-renderer-for-daz-studio/110993
  • LeanaLeana Posts: 13,625
    No, it's a different product.
    This is what I've been using that works with Iray:
  • posecastposecast Posts: 386
    Thank you! Invaluable!
