Getting rid of textures
Hello.
Is it possible to deactivate the textures in an object, and get only the plain grey model?
  • WilmapWilmap Posts: 2,917
    You need to go to the Surfaces tab and remove all reference to textures, bump maps etc and colours, then you'll get the basic non textured item.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Save a shader preset (File>Save as>Shader preset with a single surface on a single object selected) with your grey settings and you can thena pply it to any selected item's selected surfaces - right-click on the saved file in the content pane and Create Custom Action to have it available from the Scripts menu (or use Window>Workspace>Customise to move it to another menu or toolbar).
    Thank you very much.
  • Save a shader preset (File>Save as>Shader preset with a single surface on a single object selected) with your grey settings and you can thena pply it to any selected item's selected surfaces - right-click on the saved file in the content pane and Create Custom Action to have it available from the Scripts menu (or use Window>Workspace>Customise to move it to another menu or toolbar).
    That's another possibility, thank you.
