Riccardo Hair and Duplicate IDs
luci45
I recently bought Riccardo Hair, a new product. Whenever I load it I get a message - "Duplicate IDs were found while reading the file see log file for more details" This used to happen a lot a few years back and there is a script that used to fix it. I tried the script and it only fixes .dsf files, not .dufs.
When I contacted customer support I was told it is because I have the product installed twice, through DIM and DAZ Connect, which is not the case. It is only installed though DAZ Connect. Can this issue be fixed or should I just return the product? The error report in the log file is below:
2016-02-19 19:02:17.225 WARNING: fileinput\dzassetdaz.cpp(4560): Could not find node parent.
2016-02-19 19:02:17.262 Duplicate id "FHMKenji7" found in file "/data/Linday/Riccardo Hair/Riccardo Hair/Morphs/Linday/FHMKenji7.dsf"
2016-02-19 19:02:17.267 Duplicate id "FHMKenji7-1" found in file "/data/Linday/Riccardo Hair/Riccardo Hair/Morphs/Linday/FHMKenji7.dsf"
2016-02-19 19:02:17.346 WARNING: fileinput\dzassetdaz.cpp(1720): Failed to follow node.
2016-02-19 19:02:26.755 File loaded in 0 min 10.7 sec.
2016-02-19 19:02:26.771 Loaded file: riccardo hair.duf
2016-02-19 19:02:26.802 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-02-19 19:02:27.106 Loaded image l hair trans.jpg
My script helped only with items where the figure and geometry name matched, which older DS versions allowed, so it wouldn't help here. I did buy this and I am getting the same issue, again with only a Connect install. I will have a poke at the files later.
I have this issue too. The hair is loaded but I get the same error message. So this isn`t fixed after 2 years?
I installed it only with the content manager, too.
2018-02-24 09:30:12.766 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Device statistics:
2018-02-24 09:30:12.766 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070): 97 iterations, 16.078s init, 30.329s render
2018-02-24 09:30:26.128 Duplicate id "FHMKenji7" found in file "/data/Linday/Riccardo Hair/Riccardo Hair/Morphs/Linday/FHMKenji7.dsf"
2018-02-24 09:30:26.143 Duplicate id "FHMKenji7-1" found in file "/data/Linday/Riccardo Hair/Riccardo Hair/Morphs/Linday/FHMKenji7.dsf"
