Having a problem with Render Studio Monochrome
Wonderland
in The Commons
I'm having a problem with Render Studio Monochrome that I'm not having with the original Render Studio. When I load a second light using Control (Mac) merge into scene as described in the video, the first light is deleted. I can't get two lights in the same scene. This doesn't happen with the first product. Am I the only one with this problem??? How can this be fixed? Thanks.
In Windows holding down Control then double clicking on the icon for the light you want to add brings up a pop up box where you can choose to either replace all the current lights or your selected light or add the new light - I just choose add light
If I right click & merge then it replaces any other lights in the scene
Not sure if this will help you as you are on mac
Hmm, weird, I was able to add lights from the first Render studio to a light I already created in Monochrome using the merge method. I don't have a right click mouse on my Mac so usually control works for that. Maybe I should try option or shift? The pop up menu to merge into scene happens when I hold down control, maybe I should try double clicking at the same time... But weird how the merge option works in one product but not the other. I'm rendering something now, I'll try the other keys after and if that doesn't work I guess I can try contacting Colm on Facebook...
