V4 clothing not auto fitting
Okay this is a new problem, when I load clothing onto a v4 figure, it is not "auto" fitting to it. It shows up in the right spot, but when I pose the character it doesn't move with it, until I right click and select the parent. Normally in the past as long as I have the V4 character selected and then put on the clothing it fits and when I pose the character it already "stuck" on. Is there some setting that was changed?
Thanks!
Amy
  • LyonessLyoness Posts: 1,641
    you need to purchase this outstanding product... http://www.daz3d.com/wear-them-all-autofitting-clones-and-clothing-smoothers-for-genesis-3-female-s
    with that you will once again be able to auto-fit V4 to G3F
  • scorpioscorpio Posts: 8,534
    Thanks!
    Amy
    Do you mean auto conforming rather than Auto fitting? Some things don't auto conform go to the parameters tab and there should be a box where you can select the figure to conform to. Or right click on the item and choose conform to from the list.
  • SassanikSassanik Posts: 340
    No this is for V4 character wearing clothing made for V4
    Then, it's not autoconforming an you will need to select the clothing item and do a manual 'fit to'...either in the parameters tab or right clicking on it in viewport.
    It seems to me that it used to autoconform before and that a setting or something is off? I don't remember having to do a manual "fit to" on items designed for V4 on a V4 character in general?
  • KarenKaren Posts: 115
    Not sure, but maybe the preference (Auto-magnetize to figures with D-Forms) settings changed somehow? Happened to me once.
    580 x 789 - 106K
    CMS automates the Fit-To for items that did not have it set.  Is CMS working?
  • BejaymacBejaymac Posts: 2,014
    edited June 2016
    Standard problem with most Poser content, it's been saved back to the library as a figure rather than as a conformer, as a result the auto conforming setting hasn't been set right in the CR2.
    Open the CR2 in a text editor and find the word conforming, after it will be a 0, change that to a 1 and save the changes to turn on the auto conforming.
    Post edited by Bejaymac on
