2 products questions
CherubitCherubit Posts: 995
Does this product come with the textures from the 3 dresses in the first picture? http://www.daz3d.com/morphing-fantasy-dress-for-genesis-3-females
And if I don't have the required product in this one, I cannot use this product in any way? http://www.daz3d.com/gis-biosuit I was really considering buying it.....
Post edited by Cherubit on
  • MelanieLMelanieL Posts: 7,866
    edited June 2016
    First question: unfortunately not. They are all three add-on textures:
    http://www.daz3d.com/princess-of-darkness (the black one)
    http://www.daz3d.com/princess-of-eire-2 (the grren one)
    http://www.daz3d.com/princess-of-romance (the pink one)
    Second question: you will be able to use it on the Genesis figure or (I think) any figure based on Genesis, such as Victoria 5, Stephanie 5, ... because Genesis comes with support for the V4 texture UVs.
    You will only be able to use it on a Genesis 2 figure (Victoria 6, etc) if you buy the required product - if you try to use it without then there will likely be gaps or strange effects where the textures don't line up correctly.
    Post edited by MelanieL on
  • CherubitCherubit Posts: 995
    Oh thank you so much! But even if I fit (2) in G2, it will look weird? I wanted that one...
  • LeanaLeana Posts: 13,499
    GIS BioSuit's suit part is not a real outfit, it's a body texture. So if you don't have "V4 for Genesis 2 Female" it won't work properly for G2F.
    edited June 2016
    Yes, it will look wrong on G2F unless you get the V4 UV's product. Here's what happens - first is the Biosuit on the G2F Base Female with the V4 UVs available, second is using the Base Female UVs - you can see the gaps.
    560 x 870 - 122K
    605 x 864 - 97K
    Ohhh I seeee! It's because those textures go to the body of the character! :O Makes total sense! Thank you very much!
    Oh I see! Thank you so much for explaining! Makes total sense now!
