DSON Importer for Poser 11 Pro
Hello, I have Daz Horse 2 and a few other items that need DSON Importer.  Is there an upcoming update, patch or new version to support Poser Pro 11
  • Richard HaseltineRichard Haseltine Posts: 111,898
    Poser Pro 11 is supported - if you use the Daz Install Manager that version should be one of the options when adding an application to preferences.
  • Poser Pro 11 is supported - if you use the Daz Install Manager that version should be one of the options when adding an application to preferences.
    I have install manager and DSON Importer appears but when I try to install it appears to be for Poser Pro 2014 as it will only extract itself if I choose Poser Pro 2014 in applications settings.  i can access the extracted. DSON files is there I can manually set it up?
