black teeth
Drogo NazhurDrogo Nazhur Posts: 1,353
When I render my character -- the teeth shows up almost black ==> http://orig10.deviantart.net/1a42/f/2016/162/a/e/black_teeth_by_dim357-da5w9ha.png
How do I fix that?
Post edited by Drogo Nazhur on
    Are you using Iray shaders/presets on them?
  • Drogo NazhurDrogo Nazhur Posts: 1,353
    I'm using Iray and whatever the defaults are. I'm not even sure where to check for that stuff?
    Select the teeth in the Surfaces tab and see what it says under Shader (up at the top of the list).
    Can't find teeth. Found skin, lips and nails. I'm using G3F
    Never mind. I found it. Thanks everyone.
