Empty Render? (SOLVED)
l_stowel_stowe Posts: 172
edited June 2016 in New Users
OK, so I'm a bit baffled by this one. I have a scene with lights and a camera. Environment is set to scene only and when I render with iray all I get is an empty render. e.g. a transparent image.
Any clues? :/
Post edited by l_stowe on
  • Richard HaseltineRichard Haseltine Posts: 111,363
    So there is a model of some kind in there?
  • l_stowel_stowe Posts: 172
    edited June 2016
    yeah it's bizarre. I'm at work at the moment, but when I get home I'll try and take some screenshots and show some of the settings if I can.
    UPDATE - RESOLVED
    I've just logged into my machine at home to see some of the settings again and think I've figured it out. It appears that I had moved the camera down to below ground level to render a dramatic angle. I've just moved it back to Y translate of 0 and it works! Doh.
    I'll have to remember that for next time.
    Thanks for the reply though Richard.
  • DDCreateDDCreate Posts: 1,421
    I render the inside of walls a lot. It's not just you I-stowe ;)
  • I am wanting the low angle render but I am running into this same problem. Is there a fix that still allows me to have this desired low angle?
    Thanks
    James
    @jalillich I'm a total beginer in daz but moving camera and the model above ground level helped ;) (I do not render whole scenes though, only the model)
  • For low angle shots below the ground plane remember to switch OFF the "Draw Ground" option in the Render/Environment panel. (Gets me every time)wink
