Blood Red outfit doesn`t work correct for my character / Shape Shift morphs
cosmo71cosmo71 Posts: 3,609
edited June 2016 in The Commons
Have bought the Blood Red outfit but the top doesn`t work correct. Have a look at the image that shows the outfit after loading to G3F. I use DS4.8
1680 x 1050 - 215K
Post edited by cosmo71 on
    It's probably something on your end as I have been playing with it for the last few hours in 4.8 and have not had that happen to me, so you might want to edit the title of the thread.
  • cosmo71cosmo71 Posts: 3,609
    edited June 2016
    Why should I, it does not work correct. I use DS4.8, I use G3F, I use the blood red outfit and it does not work.
  • nattaruknattaruk Posts: 547
    There does appear to be a problem; I have raised a support ticket with Daz. It seems to depend which figure is used. From left to right, Isa, Lexi, Rune:
    1350 x 765 - 332K
    And it is the only clothing set I have that does this error, all other sets work
    Well, have found the morph that causes that result. It is a morph of the shape shift product by Zev0 - Genital size morph
    I have created my character with Shape Shift for G3F and the morph that causes the result in the image I have posted it the genital size morph
    Sorry it is not only this morph, seems to be a combination of Shape Shift morphs
    So it was something on your end?
  • CzexanaCzexana Posts: 167
    I'm getting the same effect too with certain morphs - the front loin cloth of the top skews and expands on a diagonal front left/back right when any of these morphs are dialled in. Lexi and some morphs I transfered from G2F are the ones I've noticed it with but I doubt that's an exclusive list.
  • takezo_3001takezo_3001 Posts: 2,041
    edited June 2016
    Try to set smoothing as generic rather than "base shape matching" under smoothing type.
    Post edited by takezo_3001 on
    edited June 2016
    I have tried adjusting the smoothing type; this has no effect at all on the problem.
    Also, whilst the use of the shape shift morphs may aggravate the problem they can not be the main cause because I have a problem with the outfit but I do not have those morphs.
    I have tried fitting the outfit to the base G3F figure and then adjusting the body shape morph. It seems to be OK with the main '7' characters but the problem appears, to varying degrees, with most, but not all, of the other body shapes I tried.
    Post edited by nattaruk on
    seems to be something on a lot of ends
    have loaded my character, copied it to a fresh loaded g3f, and went through the Shape Shift morphs and zerod one after another and on one morph the top looked correct then but then I copied my character again to the g3f figure and just zeroed this one morph that made the top looking correct after zeroing at the first time and nothing. So I guess it is a morph combination that causes this error.
    If you still cannot get it to work, I would simply ask for a refund, as the entire point and tech of the genesis characters are their near infinite morph ability, as clothing is supposed to fit any shape!...Otherwise it's just like working with the Mil-generation...
    edited June 2016
    question is, why don`t have other clothes not this error (also skirts) ???? This is the only clothe that have this issue and it seems that other users also have some issues with it.
