How to disable auto transition between frames?
Hello, I'm having some problems with the auto adjustment between frames. Even if I create new keyframes in the timeline Daz would add some tilt based on my last keyframe.
I'm trying to animate a camera to move forward and then do a side rotation, Daz keeps adding some rotation in the zooming.
  • Richard HaseltineRichard Haseltine Posts: 110,003
    You need to change the interpolation type - casual has a free script to do this, or you can use the KeyMate plug-in http://www.daz3d.com/keymate
  • Hello everybody. I need to add many animations to a single model one by one and if I change the pose DAZ creates a transition animation between Pose #1 located on the keyframe 1 and Pose #2 located on the keyframe 10.
    Is there a way to say to DAZ to stop doing that?
    I've tried to find a workaround and to locate Pose #2 just after Pose #1 and to make a safety area of frames between them in 3dsMax, but faced transition is still existing and is compressed virtually bewtween frames #1 and #2.
    It is a one-time operation for me, so I don't want to invest to the Keymate.
    Is there is a script to switch DAZ transition off, pls, help to locate it (casusl isn't easy to find with search).
    Thank you!
