Purchased Products not available to download
Since coming back to D/S and getting to grips with Daz Connect, I have come across a recurring problem of items I've just bought not being available in Daz Connect.  It is mainly new releases., which leads me to wonder if there is a backlog loading the items? I am however prepared to accept I am doing something wrong.  Either way, it is frustrating.  Is anybody else experiencing this problem?  Is there anything I can do to fix it.  I even tried a manual download with the Textures for Blood Outfit and Textures Chevaleresse but the files were invalid.  Hay-ulp!
  • Richard HaseltineRichard Haseltine Posts: 111,362
    Items can take a while to show in Connect. Which filse were invalid for the textures ets - the offlien packages or the DIM zips?
  • Amy_BoneAmy_Bone Posts: 45
    The Manual Download files (which I would guess is the DIM zips)
    Have you tried using a different archive tool? The built-in Windows comressed folders utility can be touchy. Failing that, try using a different browser (or the Install Manager) to download.
    I tried using the manager and it just hangs apparently indefinitely.  I gave up after I got back from the shops and it still hadn't finished synching.  I've reacquired the zips and they work now so iot may have been a connectivity issue with my ISP, so it's no biggie.  I've just gone through my recent purchases over the last five days.  About 75% had to be manually installed despite none of them being more than 2-3 months old.  I guess for the time being I have to assume that Smart Content is not going to be much use and I'll have stick to manual downloads using the content library for the forseeable.  bit of a shame because, in principle, smart content is a good idea.  Thanks for you help though.
    Even if you install manually you can use the Re-import metadata function to get the smart metadata (if you install with DIM it will be imported automatically).
