How to reset IRay surfaces?
I've hit this issue several times. I apply an IRay preset (it might be the Uber shader) and then try out other (purchased) shaders. Once I do that I don't seem to be able to return to the Uber shader or the original that I started with. I generally need to reload the character or prop which can be a real PITA.
So is there a way to remove a shader and go back to a previous state?
  • fixmypcmikefixmypcmike Posts: 19,729
    Do you mean you can't restore the Iray Uber shader, or you can't restore the original settings?
  • marblemarble Posts: 7,500
    edited June 2016
    Either and both. If I have the Uber shader active and then select another shader (metal or lace or satin, etc.) then the settings change as you would expect. But there seems to be no way to return to the plain Uber shader. Clicking on the Uber shader preset doesn't ignore the previous shader settings. Also, If the product came with a custom shader and I try another instead, I can't return to the original.
    Post edited by marble on
    I wouldn't expect the Iray Uber base to change any settings, but I would expect a custom shader for the product to do so.  What's displayed at the top of the Surfaces pane when you apply the second shader?
    I'm not on that PC right now. I'll check later.
  • JimbowJimbow Posts: 557
    Does saving the initial Uber shader as a shader (not material) in My Library give you a clickable workaround?
  • MortzeMortze Posts: 186
    Sorry to ask but have you tried Ctrl+Z to go back on the shadder move?
    Sorry - have been away for a while. Here's what is happening:
    • Load figure and clothing (3DL presets only)
    • select cloth, find IRay Uber shader preset and double-click (item selected in scene and surface tab, of course).
    • Check surfaces tab - it now says Shader: Iray Uber
    • Select another IRay fabric preset  from those I have purchased. Double- Click one and make sure that is applied.
    • Keep selecting and applying different materials until I find one that looks good.
    • Shader:Iray Uber is still at the top of the Surfaces tab throughout.
    • Attempt to reset to plain Iray Uber by double-clicking the general Iray Uber preset. Nothing happens. The last shader material is still showing on the cloth.
    • CTRL-Z does step back through the selections but, by this time I may have tried many.
    • There is no reset utility. The only way I can reset is to return the cloth to 3Delight and start over.
  • Richard HaseltineRichard Haseltine Posts: 111,677
    Apply the base shader, then save a new Shader Preset and make sure you include all properties (or all values if you don't want to change the maps in resetting - or you could save two new presets, one affecting maps and values and one values only). Use the option menu at the side of the dialogue to control what gets saved.
    I thought the Uber Shader was a shader preset already?
    Yes, but a shader preset can make many or few changes. Most presets have an option dialogue after asking for the name which allows the user to choose exactly what will be included in the preset.
    OK thanks - I'll give that a try.
