Anybody knows how to create/save expression presets for M4/V4
Greetings to all:
I am new here and would like to know if anybody has a clue about how to create/save an expression preset for M4/V4.  I've looked everywhere for a clear, step-by-step explanation and there is nothing to be found.
Cheers!
  • nicsttnicstt Posts: 11,715
    edited June 2016
    I saw you other post, but decided to answer here. :)
    File > Save As > Pose (don't think it is likely to be Shapeing, and I've never used it, but if one doesn't work, try the other)
    This brings up a pose save option - chose range of single frame.
    Expand Genesis 3, and then expand Expressions
    Uncheck what you do NOT want, and ensure only what you require is checked in the various sections.
    You can save it in the default area Daz choses; I have my own customised folders and catagories, so you can also save it anywhere.
    Click merge (to apply the expression), and you can select the expression from the place you saved it -
    - alternatively, it is placed within Daz; I forget where as long time since I used it.:)
    EDIT
    Oh and as Daz saves a thumbnail, you can position the camera/viewport to capture the 'shot'.
    Post edited by nicstt on
  • Hi, sorry I did not thank you for your help, but I just wasn't able to check this thread until today,  Apologies!  Also, I use M4/V4.  Is the procedure the same if I use these instead of G3?  I'm going to try your tip right away, but I am asking you only in case there is something I miss.
    Thanx again!
