hide spotlight, but still emit light?
mcorrmcorr Posts: 1,105
edited June 2016 in The Commons
Hello All ... how do I hide a spotlight in front of the camera (so that it won't be rendered), but still have the light from the spotlight emitted?
Thanks
Post edited by mcorr on
  • KnittingmommyKnittingmommy Posts: 8,191
    edited June 2016
    In Iray, one would turn the opacity cutout of the light (in the surfaces tab) down to something like 0.0001 or some rediculously low number.  I have no idea if it works the same in 3Delight.
    edit: to add where cutout opacity is located.  just in case.
    Post edited by Knittingmommy on
  • mcorrmcorr Posts: 1,105
    I was wondering about that. Thanks! Seems like something Daz should just have a button for.
  • ToborTobor Posts: 2,300
    For a a spotlight you turn off the Render Emitter option. The light disc won't appear, but it will still produce light for the render.
    That's awesome ... I thought I tried that, but will try it again. Thanks!!
  • macleanmaclean Posts: 2,438
    That only seems to work sporadically for me. It's a 'Now you don't see it, now you do' kind of thing.
    I've had the same experience and, therefore, thought I was missing something, or had done something wrong.
    The Render Emitter setting will always work as long as the light is in *direct* view of the camera. The emitter will render if in reflection, or when seen through a volume. This is simply how Iray works. If these can't be avoided, you can reduce the spotlight emitter to Point, which makesit very tiny, but then you get harsher shadows.
    For a spotlight, there's no Opacity setting -- this works only for emissive objects.
