Macro Wet Maps g2f (how to use in iray?)
Hi guys,
I have a question about this product http://www.daz3d.com/macro-wet-maps .Its is made for 3Delight but i want to change it to iray. I tried a bit but i dont got what i wanted. I tried it with only iray uber base and change some different areas but it dont did what i want. Ok i thought i use the same shader how this product use http://www.daz3d.com/so-wet-bundle-for-genesis-2 but than i couldnt see anything of the wet map.
I hope someone can understand my terrible english and can help me :)
great K4YT0
  • evilded777evilded777 Posts: 2,515
    Some things just don't translate across render engines.  This, if I remember correctly, is one of those things that just won't.  It relies on the 3Delight engine to do what it does. I could be wrong... but I'm pretty sure its just not the product you need.
  • i dont know cause all maps are there but i dont know why i dont get the result :/ maybe the bump map isnt the best or something else
  • the product is only a shader. that is what i cant understand why i cant change it and get the same or better version in iray
  • fixmypcmikefixmypcmike Posts: 19,718
    A shader can be simple or complex and is renderer-specific -- how easily it translates to a different renderer varies.
