Keep render window after saving?
thewayurthewayur Posts: 11
edited June 2016 in New Users
Is there a way to keep the render window after hitting the save button? I want to keep the window to compare it with other renders but to secure it, used to save it. Any trick?
Post edited by thewayur on
  • fixmypcmikefixmypcmike Posts: 19,743
    The render window should stay open after saving if you don't click the Close button, at least in Iray.
  • thewayurthewayur Posts: 11
    nope, it closes as soon as i clicked SAVE (not close) since 4.7 to till now
  • Richard HaseltineRichard Haseltine Posts: 112,079
    edited June 2016
    Try File>Save last render. If you want to compare renders there's also Render>Render Editor, which should ahve your recent renders (from the current session) at the bottom - drag two into the boxes at top-left and then go to the Compare tab at top-right to be able to wipe between them.
    seems life saviour. Thanks
