How can I see the rendered output of my objects.
I've scanned the manual etc and also examined all the menus on the Hexagon program and I cannot see for the life of me - an option to render / view the object as it is without all those lines.
... and whilst I am on the subject of viewing objects, can you apply material effects to the surfaces in Hexagon or is that done later in Bryce - should I expect to model in white only surfaces?
Thank you in advance for your feedback.
Terry
Look on the left-hand side of your work area, and click on the little blue arrow mark in the middle.
This opens up the materials window, and here you can assign colors and/or texture maps to the various materials.
Colors can be assigned to materials with or without the model being UV mapped, but to apply TEXTURE MAPS you must UV map the model first.
Probably the best way to see how this works is to get an OBJ file of a model that has already been mapped and textured. Load that model into hexagon and hexagon will load and assign the colors and textures from the OBJ file's MTL file.
If you look way down in the bottom right corner there is a camera - that lets you do a render of the current view - the sphere next to it does this with ambient occlusion and the last two spheres in the fourth box from the right lets you do a view or render under different light conditions and with AA and shadows.
You could export your object as an OBJ file and render it in Daz Studio, it is free at the moment so why not give it a try.
