Easy Environments and Iray Tips and Tricks
Ken OBanionKen OBanion Posts: 1,456
Hey, folks --
This may come across as kind of a 'newbie' question, and if it does..., who cares?
I really like the Easy Environment scenes from Flipmode (sp), but I can't seem to get them to work properly with the Iray render engine.  I'm assuming that the issues I'm having involve both lighting and shaders.  So....
If anyone can offer a few tips and tricks to get those environments to render properly in Iray, I'll appreciate all over ya!
  • KindredArtsKindredArts Posts: 1,354
    Hey, folks --
    Could you be more specific on the issues ken?
    Have you changed the default shaders to iray shaders, and what lighting set up are you using? Dome, scene, sun/sky?
    Also, it looks like flipmode has noted the subject of IRAY rendering on their website, here - http://flipmode3d.com/easy-environments/#skyspherehdr
  • MelanieLMelanieL Posts: 7,867
    edited May 2016
    Hey, folks --
    There was a post by timmins.william here: http://www.daz3d.com/forums/discussion/comment/1131486/#Comment_1131486 I seem to remember other posts somewhere too, but I didn't boookmark them.
    ETA: Ah I found one from the horse's mouth: http://www.daz3d.com/forums/discussion/comment/825330/#Comment_825330
    Post edited by MelanieL on
  • Oso3DOso3D Posts: 15,115
    I actually just did a Snowy conversion. I ended up using a geoshell. If you drill into the weird 3dl shader, there's an image mask for the snow that you can use on the geoshell, creating a very nice transparency for the peaks to, er, peek through.
    The result (the actual rock and snow are my own shader, the image mask from land of ice and snow): http://willbear.deviantart.com/art/WTZ-Land-of-Ice-and-Snow-611210383
  • Ken OBanionKen OBanion Posts: 1,456
    MelanieL said:
    Hey, folks --
    Thank you both!
    I've bookmarked both posts, so I can refer to them again at my leisure.
    Melanie, you keep pulling my chestnuts out of the fire!  If you keep this up, I may have to put you on the payroll!
    MelanieL said:
    Hey, folks --
    Thank you both!
    Well, my services are cheap enough to buy for the Bijou-man! laugh
