Is there any difference ,save as "subset" and "scene" about same figure?
kitakoredazkitakoredaz Posts: 3,526
edited May 2016 in Daz Studio Discussion
I edit, steps. ( temporal morph is morphs,,  which not be saved as morph assets, it is made for  current scene only)
Because it only  happen when I save genesis3 with temporal-morph applied,  and with  clothing (fit to genesis3female) as scene.
1. delete all in the scene
2 load genesis3female, set  base resolution. then import "temporal morph" by hexagon bridge or morph loader,
(eg,, just change scale genesis3female  twise , then import it as new morph by morph loader, or hexagon bridge)
apply the  new morph value to 100%
3 load any clothing then fit to genesis3female with tempmorph value 100%.
4 Now I can see, the clothing auto follow morph without problem.
5 save it as scene. (figure with clothing, ) (newscene.duf)
6  save only genesi3female with tempmorph value 100%, as scenesubset  (newsubset.duf)
7.  load  scene = newscene.duf, I can clear see,  genesis3female which deformed by tempmorph value 100%,
(that means,, the scene include temp morph data, which not save as morph.  I change  the figure labell , as "genesis3female_scene" to check easy.
8 but  the clothing can not auto-follow temp-morph any more. only the Figure deformed by temp-morph.  then clothing not fit the current morphed shape.
9 load  subset = newsubset.duf, on current scene,  it should load same genesis3female  then now I have two genesis3female ,defromed by same temp morph 100%. I rename the second genesis3female labell as genesis3female_subset.to check easy.
10, select "genesis3female_scene" then load another shirt, it fit to genesis3female_scene, but  the shirt can not auto-follow, the temp morph.the genesis3female lost ability to auto-follow about temp morph. so that any clothing can not auto-follow the temp morph.
 11  select "genesis3female_subset" then load new shirt, it fit to genesis3female_subset the shirt can auto-follow the temp morph.
 I really confused, why support team can not re-produce this problem.. Now support ask me, to close  ticket.
 Is it really happen only for me?
1726 x 921 - 335K
1586 x 879 - 298K
1617 x 886 - 306K
Post edited by kitakoredaz on
  • RuphussRuphuss Posts: 2,631
    never heard of this tempmorph
    "then import "tempmorph" by hexagon bridge or morph loader"
    edited May 2016
    Temp morph means, any moprh which you can make (eg just change full scale, then save it as obj,, then import it as new morph.) as you like,
    , but not had been saved  as morph assets.   in this topic,, I save it as scene with the clothing. (and scene subset, to compare it)
    (so that I call  it is temp =temporal  morph,, these morph may only  work about the scene or subset, but when you load new genesis3
    the morph should be disappeared from parameter.)
    Sorry it is  my fault,, tto use such wrong words,,   (I believed it can be understand,,)
    then hope you just test it as same as my step , then tell me,, you find same problem, or not.
    I have same test maybe more than 10 times. when I get reply from support about same ticket.
    (I re-install genesis3 essenceals, and up-date all version. then I see same effect.
    so that I can not believe  it is only happen with my PC.
    And actually there was one user who asked  about this problem in forum .
    then I test and confirmed..  and promised to send report  ,, but dev teams had said they can not re-produce it.
    But see my pic,,,  actually it not work for me.
    or Is there  special case,, the morph (which set as enable auto-follow)  of figure ,
    can not auto-follow for the clothing (fit to the figure)?
    1318 x 770 - 343K
    1608 x 861 - 372K
    thanks for explanation
    i love creating words
