Transfer utility
TemairTemair Posts: 89
When making a top for genesis and then using the transfer utility if I then put genesis as a female the top moulds around her breasts
Have tried using genesis in hexagon as a female and using the transfer utility on a female genesis and top and it still does the same even though it is not modelled that way in hexagon
How can I stop that happening?
Thanks
Angie
  • Richard HaseltineRichard Haseltine Posts: 112,089
    You have two options - the Clothing Cleavage Modifier morphs will add a hidden morph that pushes the cleavage out, or you can create your own morph for Basic Female in Hexagon to replace the automatically generated one.
  • TemairTemair Posts: 89
    Thank you Richard will have a look at both options
