Cobra Queen Face doesn't match body with Iray
GatorGator Posts: 1,320
I just picked up the Cobra Queen, I noticed her face & ears color doesn't match the body.  I checked sufaces for like transparancy and color & values seem to match.
1920 x 1080 - 1M
1920 x 1080 - 1M
921 x 1321 - 200K
    Make note of the maps used on the face then select the Torso, in Surfaces, right click and Copy selected...then select the face and paste...replace the maps with the proper ones.   That will make sure the settings match.  If they are still 'off', then compare the maps...it may be that one has an embedded color profile or wrong gamma correction.
  • RawArtRawArt Posts: 6,220
    You are correct...there is an issue.
    This was made with d/s 4.8, likely when iray changed their settingf for 4.9, something burped.
    I will get on a fix first thing tomorrow and get it uploaded to daz.
    Still...please submit the fix request to daz, so they have a record of it.....because that is the proper way to get fixes made. I just happened to be in the forums today and saw it. But that doesn't happen all the time
    Rawn
    Ok....I have fixed the settings and uploaded the new files to DAZ.
    They will test them and get them up in the store as soon as they can
    Rawn
    738 x 861 - 242K
  • evilded777evilded777 Posts: 2,549
    RawArrt rocks, just sayin'...
    hah..thanx :)
    I try to make fun things
  • GatorGator Posts: 1,320
    You rock!  Thanks!
    I was comparing settings and for the life of me couldn't find a difference.  When I selected Skin, I didn't see any ? values so I thought they all matched.
    What was your secret to find it BTW?  smiley
  • CzexanaCzexana Posts: 167
    You rock!  Thanks!
    Likely it was the default gamma setting on one of the images (can see this setting in the Uber Iray shader by right clicking on the image and opening Image Editor). I've seen this sneak through QA occasionally on other products frown
    You rock!  Thanks!
    Honestly...I could not find it either...so after wasting an hour trying, I decided to simply start from scratch and work from a fresh figure.
    It gave me a chance to update my settings with all the new iray tricks I have learned since then (that was very early on in iray when I made that).....so it is a worthy update now :)
    Rawn
  • argel1200argel1200 Posts: 760
    I would give you an upvote for that if the forums supported it. Nice job RawArt!
    I just got a notice from DAZ that the update is now live in the store
    Rawn
