Mimic ready V4 crashes in Mimic lite?
After adding "Victoria 4 Phonemes" CR2 from poser to the Mimic lite library I click the charater to begin work in but get an error:
"Error reading a node in the CR2 tree"
Note this is plain "Victoria 4 Phonemes" with no extras?
  • Richard HaseltineRichard Haseltine Posts: 111,282
    Do you have Use External Binary Morph Targets set in Edit>General Preferences>Miscellaneous tab in Poser? If so turn it off and resave the CR2.
  • MouserMouser Posts: 775
    Thanks that solved the CR2 error but the figure's lips do not move?
    Session manager Settings are:
    RealBlonde.wav
    RealBlonde.txt
    V4 Mimic.cr2 (copied from V4 with phenomes mimic ready)
    Victoria4.dmc
    Is there a setting I am missing here?
    Do the morphs work in Poser itself if you reload the figure?
    Yes both origional and the copy both lips and jaws move.
    And you turned external binary moprh targets off before resaving the figure? I don't know why it would fail in that case.
    Neither do I, V1 works okay?
    Victoria 1 has all of the morphs pre-loaded.
    Mimic ready V4 has morphs as well?
    Mimic ready, I think, means it has the phoneme morphs but has most or all others removed to reduce the footprint.
