Save LOD level of detail no working
I'm loading several levels of detail and they work fine. Save the project, load it again and everything is OK but level of detail are missing. How can I save them?
The manual says "Make sure that the different meshes needed are in the correct Geometry folder for the figure." but not sure what folder they are talking about.
  • Cris PalominoCris Palomino Posts: 12,963
    Which program?
  • karlakimorkarlakimor Posts: 15
    I'm using DAZ3d. The models come from Zbrush.
    As aditional a test I have created an sphere in DAZ, exported it as an OBJ and loaded it as as LOD in edit->object->geometry->add level of detail.
    It works, but as soon I save it and load it again the LOD disappear. Again, if I'm suppose to save that OBJ in a specific folder I don't know what folder is.
  • Richard HaseltineRichard Haseltine Posts: 111,362
    edited May 2016
    There is another thread with the same issue, so it does seem to be affecting others. Please open a support ticket so that the developers can get a better picture of what is happening. http://www.daz3d.com/forums/discussion/54246/
    Edit: apparently this is currently a limitation of the .duf format so no need for a report, it is known. For now you would have to apply the LoDs manually when needed.
