glitching render..
AlfawulfAlfawulf Posts: 174
Gives me this before it starts..
3Delight message #43 (Severity 0): R2093: object 'shapematerial_WoodMidRight_11461_2b4f' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omShadowSurface') used only 45% of its displacement bound
any ideas?? fix??
  • KhoryKhory Posts: 3,854
    My fix was always ignore. Severity 0 pretty much means it doesn't mean much of anything. Unless there is an issue with the way that displacement looks in the final I wouldn't sweat it.
  • Richard HaseltineRichard Haseltine Posts: 112,067
    No fix needed. It's telling you, if you are a shader author working on a film where saving a fraction of a second on an object that is in a lot of frames can save a lot of time/money, that the displacement bounds (how far away from the base mesh the renderer looks for displaced mesh) could be shrunk a bit. If you are a shader author and your shader is very slow to render it may be worth adjusting settings, but in practice it probably isn't an issue.
