Problem with "Light It Up Iray Lights"
Light It Up contains two nifty "Skin Shine" glossiness settings.  They work beautifully on Genesis 3 Female and Genesis 3 Male, but there's a glitch with all Genesis 2 figures.  With Genesis two, the glossiness applies correctly to all the body parts except for the hip area. On the hip there's no glossiness.  I've tried Genesis 2 figures with all sorts of Iray skin textures, including the IG series and the Uber Iray setting.  I've even tried them with geoshells.  No luck.
Is anyone else having this problem?  If so, have you found a work-around?  I mostly use Genesis 2 figures and so would really like to get this working.
  • Richard HaseltineRichard Haseltine Posts: 111,302
    select the hip area with the Surface Selection tool and apply the base shader to it, then select the toorso area and use Edit>Copy>Copy Selected Surface, then reselect the hip and Edit>Paste>Paste to selected surface(s).
  • kthedrickkthedrick Posts: 25
    Wow. I have no idea how, but that worked.  Thank you kind stranger. =-)
