How can I combine two skins?
How can I combine the skin of the two arms in the image attached? I want to replicate the effect in the other image attached
Thanks! laugh
1440 x 860 - 165K
1024 x 640 - 144K
    Two options...use the LIE and a mask or open the main skin in an image editor as the 'base' layer, then open the one you want to merge as another layer...then erase/blend/merge/whatever it takes to blend them to whatever effect you are wanting.  Then save that as a new map and manually plug it in to the Diffuse channel in the Surfaces tab.
  • Oso3DOso3D Posts: 15,115
    Another option is to use a geoshell and a mask to control what part of the underlying skin shows through. It can be tricky, though, because you have overlapping translucency effects to worry about.
  • Thanks for the quick answers! but I I can't understand anything sad
    Is possible to replicate that effect for a beginner? I need to watch some tutorials before trying this?
  • CybersoxCybersox Posts: 9,913
    2 questions -
    1 - is this for a still render or animation
    2 - are you trying to get the effect of an extra forearm, as your rough version seems to indicate, or a hand turning into an alien hand s the illustration seems to show?
  • *It's for a render
    *No, I want to mix the skins of the two arms smooth
    Thanks! laugh
    1440 x 860 - 165K
