Exporting movie without background into After Effects
edited December 1969 in Poser Discussion
How do you export a movie with alpha channel to make the background invisible?
I did it long ago, but now I can't remember the right process. (Is that or they change it a lot Poser 2012, 'cause I can't find the proper quicktime codec to export the animation).
Any help will be appreciated.
PD: I'm looking for a movie solution. Exporting all frames as images is not what I did. Some ago I had the option to export the actual movie, not just a series of images. Is just I lost the manual from where I get the information.
  • Dim ReaperDim Reaper Posts: 687
    The last time I needed to do this I just used a pure green background and then removed it using chroma key in the video editing package.
    It might be worth giving it a try with a short section of your animation to see how it looks.
  • Richard HaseltineRichard Haseltine Posts: 111,922
    What's wrong with exporting an image sequence? Not only does it solve the alpha channel problem, it means it's easy to render in blocks, to recover from crashes, and to make corrections if a few frames have errors.
  • SockrateaseSockratease Posts: 813
    edited October 2012
    Not to mention it adapts to any frame rate without problems - and a png sequence is uncompressed so there's no re-compression at final render time, making for the best quality possible.
    Post edited by Sockratease on
  • kalaiykalaiy Posts: 0
    Hi,
    Im also trying to render animation with transparent background. Ive tried both PNG and Tiff image sequence but they still have background when I import into AE. Can someone tell me as how Ive been searching on online for days.
    Thanks
